Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
Sometimes I try to place a vertical onriented graph next to a 2d-intensity graph. This is especially interesting with a time-frequency plot where you want to plot some interesting frequencies next to the intensity plot.
Currently this is only possible by altering the x-y data.
By adding rotated 1-d graphs we could easily create such a graph.
I'm afraid I don't understand you yet. DIAdem has had free rotation of 3D graphs for a long time now, and DIAdem does not have any 1D graphs, whatever those would look like. I do know what you mean by a time-frequency plot, but I'm unclear what additional information you want to juxtapose next to it or how additional (2D graph?) rotation would help.
The use case is the following, if I have 2D (time-frequency graph) where the horizontal axes is the frequency and there is a relation with a different signal (speed for instance), and I would like to point out this relation I can currently create the following image by rotating the right graph.
OK, now I understand what you're saying-- thanks for the clarifications. Are you ever interested in rotating the 2D graph to any angle other than the one that inverts the X and Y axes, though? If you just want to see the Y channel on the horizontal axis and the X channel on the vertical axis, why is it insufficient to assign the curve that way?
Sometime I don't have an X-axis (using waveform data).
I can transpose the array with the curve transformation I posted, however I would expect from a profressional reporting tool the freedom to rotate a graph. Or should I try to create a XYZ triplet graph?
Please be aware that rotation of a graph doesn't provide the same result as just switching x- and y-channels. One of the axes would also have to be mirrored
Your screenshot doesn't look like you could achieve the same result by rotation.
Hello
Greetings
Walter
