NI TestStand Idea Exchange
WireWeaver
Provide ability to link a Sequence File to a specific Environment File
Status: New
The concept of TestStand Environments was introduced in TestStand 2016 and allows you to define multiple configurations on a single test station or development PC. It would be nice if there was an option to link a sequence file to a specific environment, similar to how you can set a sequence file to "Require Specific Model" In the Advanced tab of the Sequence File Properties. When a sequence file is loaded, the engine could check to see if the required environment matches the current environment and:
  • Automatically relaunch the app in the correct environment
  • Generate an error
  • Prompt the user for an action
  • Other??
It would be nice to choose the behavior when a required environment doesn't match.
If anyone has other thoughts or use cases, please share below.
-Trent
2 Comments
Ash_Tesla
The Environment feature is nice but having the ability to set it within the sequence file or have the settings persist in the seqedit.exe would be nice.
ee-jallen
The environment has to be set before the engine loads.  We use a custom UI with additional settings where we can set the environment for each defined project.  But, when we do switch to a project that uses another environment, that triggers a required restart prompt for our UI, then once restarted the engine loads the new environment  So, setting different environments to different sequences is possible at the moment but requires restart.
