This may be a combo of LV and TS ideas exchanges but it affects TS mostly from my current experience. Issue occurred in LV 2022 called from TS2023. Hopefully already fixed but I know it also existed in LV2016 and TS 2016.
The issue is explained nicely in this forum post.
https://forums.ni.com/t5/LabVIEW/Packed-library-contains-folder-structure/td-p/3587329
Suggestion is to ignore the OS based heirarchy when selecting a VI in TS and to only use the virtual folder/library structure for selection of VIs to use. This will avoid all sorts of issues of paths changing on rebuild which we've just spent hours debugging.
