From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
NI TestStand Idea Exchange
LU_SDRON
Extend the Multi-Numeric Step type to the Multi-Measurement with string and Boolean comparisons.
Status: New
I have extended the multi-numeric step type to use the string and Boolean comparisons.  We have several tests that require string verification to match the exact string and to verify the string format. Therefore I have added the ability for the multi-numeric step type to use string comparisons, including regular expression for string testing.
1 Comment
ChrisHawk
There appears to be several features buried in here.
  • One to extend the functionality of them multi numeric limit test to be multi measurement test
  • One to extend the base functionality of the String value test to allow a "contains" option (and log only).
  • And another around Regular expressions (these would need to be in the TestStand engine to start with)
Not sure if this idea exchange allows the splitting of a suggestion - maybe there is another suggestion!
Either way I think all are valid and would help give clean solutions and speed up development time.
