NI TestStand Idea Exchange
Mr._Jim
Copy Full Variable Name Expression From Context Menu
Status: New
Hi all,
There are times, for instance, when I am paused at a breakpoint and I want to copy the full name expression of some deeply nested variable that only appears at runtime.
I wish there was an option on the context menu that would allow me to copy the full path of some variable.
For instance, in the following illustration I want to be able to copy the string
"Parameters.ModelPluginConfiguration.Plugins[0].PluginSpecific.RuntimeVariables.PerSocket[0]"
I've added a context menu option called "Copy Path", but maybe that's the wrong nomenclature.
Am I ignorant of some functionality that already does this? (Besides typing it in the watch window?)
Thanks as usual,
Mr. Jim
2 Comments
Shashidhar
I believe you can use these two options:
Option 1 -
The context menu contains 'Copy'. When you copy a variable and paste it in Variables pane itself, you will get a copy of the variable. However, after copying, pasting in a text editor (like in Notepad application or TestStand expression), you will get the lookup of the variable as you mentioned.
Option 2 -
Drag and drop the variable from Variables pane to a TestStand expression and the expression will use the lookup of the variable.
-Shashidhar
Mr._Jim
Shashidhar, thanks again! That seems to work well - I don't know why I didn't figure that out eventually. I still think it'd be a nice option on the menu, but I can also see why you'd want to keep the UI additions to a minimum.
