If you get memory problems, you had to tune your reports options, result collecting, load / unload modules ....
These tasks are very long, you have to point all memory consumers first ... It pollutes your test sequence only for memory purposes !
When you try to modify the result reccording, you will also have problems for your report generation ...
It should be nice to add a new feature allowing an automatic result list removing, after onTheFly reporting, ontheFly database writing have treted them ...
A kind of "OnTheFly and remove unused results"
When ontheFly reporting, and The OnTheFly database writing are over, the treated resultList should be put in a garbage structure !
Older test results could be removed if memory is needed ...
I know this could be not simple ... but this could help very much, for big sequences creation.
Thanks a lot.
Manu.net (TestStand memory dustman !)
