NI TestStand Idea Exchange
MaximeR
Add JSON string function
when manipulating data between different system, JSON string are very usefull to have a standardize, simple and readable exchange format.
Python or LabVIEW can dump structure (dictionnaires or Cluster) to JSON and vice versa.
It can be very usefull to allow to dump a TestStand variable or container to JSON and vice versa.
It can be good to have also a way to have native function in string functions to read, write or add a specific value in a JSON string.
MaximeR
Maxime R.
  CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
  CTA - Certified TestStand Architect / Architecte TestStand Certifié
5 Comments
JSlavic
I agree with this.  Python natively can determine data types "automatically".  All NI software is very manual for selecting and managing data types.  I'd like to see this more easily managed.
My last project with Python/TS, we passed data through JSON strings as it was the easiest method we could figure out to make the transfer work.
Jonathan (Jon) Slavic | Customer Solutions & Analytics Architect
Circuit Check Inc
Cell: 315-294-0035
6550 Wedgwood Road; Suite 120, Maple Grove, MN 55311
Karthik_Abiram
+1. Having native JSON support in TestStand would be very useful.
In the mean time, I had recently created a python open source library that can convert TestStand XML to JSON:
https://github.com/KarthikAbiram/tsxml
Using LabVIEW since 2012. Certified LabVIEW & TestStand Architect
HarshaBhushan
Status changed to: Under Consideration
JSlavic
any update to this??
Circuit Check Inc
Cell: 315-294-0035
Merecs.Gerrit
For information:
There is a whitepater by NI. How Can I Output TestStand Report Result as JSON? - NI
However!! They did not mention that is it still buggy in at least three points.
- Infinity and Nans are not displayed according to JSON default
- All numeric Arrays of any dimension will be displayed as 1D
- List of objects may miss the name of the object -> also not JSON default. This is depending on your TS version i guess.
Here two screenshots of Locals.Container.AsPropertyObject.GetFormattedValue("",0x1001)
I have programmed my own parser which covers this. Though the excessive Calls from the TestStand APi in my solution may lag on slower systems(exspecially with unknown virus scanners and else)
