In principle CVI supports external compilers for an optimized release version such as Intel's ICL and I managed to successfully compile release versions using ICL 11.1.
However, documentation on this issue is sparse.
It is even worse if one attempts to use an external linker which might be appropriate if one attempts to use e.g. Intel's MKL. Here I would love to see the support of external linkers in combination with an improved documentation.
Similarly, CUDA is becoming more attractive for more demanding floating point applications - I would consider it very useful if NI could provide e.g. an application note of how to do this in an easy to follow tutorial.
