From the CVI Help:
Some Interface to Win32 Application Programmatic Interface (API) functions have the same name as some LabWindows/CVI functions, causing a naming conflict. You must include the Interface to Win32 API include files before the LabWindows/CVI include files. LabWindows/CVI automatically resolves the conflict by using the LabWindows/CVI implementation of the function. To use the Win32 API implementation of the function instead, define the SDK_CONFLICT_PRIORITY macro in the Compiler Defines section of the Build Options dialog box.
If you enable the SDK_CONFLICT_PRIORITY macro, you cannot use the following LabWindows/CVI functions and should use the Win32 API implementation instead.
Formatting and I/O Library
Utility Library
Based on my experience these name conflicts have no advantages, and create a lot of problems: usually I use the CVI implementation, but it happens that after some time I need the Win32 API implementation of one of these functions (GetSystemTime(), for example).
In this situation I must heavily modify my code, changing the calls to all the above functions.
I don't like these naming conflicts at all.
I suggest that a "_CVI" prefix (or something like that) is added to the CVI implementation: an old project will recompile perfectly simply adding this prefix to the calls, without modifications to variables, structures, ...
