Add in an API structure for DOM (Domain Object Models). DOMs are usually read in from XML documents and saved out as XML documents. This allows a nice file data format, and a set of APIs with a handle to hold onto data.
Example Code:
DOM_createNew("handleName");
DOM_loadXmlDocument("handleName", "path\to\document.xml");
DOM_saveXmlDocument("handleName", "path\to\document.xml");
struct DOM_Element topElement = DOM_getTopElements("handleName");
struct DOM_Element elemList[] = DOM_getElements("handleName", element_ptr);
struct DOM_Attribute* attribList = DOM_getAttributes("handleName", element_ptr);
and so on... with setters and getters, add routines, and possibly the ability to force the DOM to adhear to a ".xls"
and then start moving the files away for old school .ini files in the saved text files.
