Given a project topology like this:
Windows PC Host <-> cRIO-9024 <-> NI-9114 backplane <-> NI-9144 EtherCAT #1 <-> NI-9144 EtherCAT #2 which is run in hybrid scan mode, during development I wish that it were possible to, for example, tell the project to run without EtherCAT #2 being physically connected, instead using virtual/simulated IO. As things stand now, when I try to switch from Configuration to Active mode, I get an error saying that "the slave device cannot be found".
More generally, I often find myself thinking that the project explorer needs a good way to "comment out" various pieces of the project without having to resort to "Remove From Project".
只有注册用户才能在此添加评论。 如果您已经注册,请登录。 如果您还没有注册,请注册并登录。
