During LabVIEW Development was a PXI Real-Time System connected (LAN) next to my Laptop and process Build/Deployment was no problem.
Now the RT has been shipped far away to customer site and i have no longer access to that network.
So I need an other way to distribute and
here is my IDEA #1: (below is another IDEA #2)
FACT : Most of all customers have no knowledge about "How to find the Real-Time System and update the Application on it".
So the new item will built an "Offline Installer.exe" and will run on any customer PC to a full automated update job automatically.
Features:
- create a detailed installation report which can be stored and send back to the developer.
- In case of the Real-Time System isn't connected to any LAN, the customer could use the "Offline Installer.exe" to prepare an USB-Stick which has to be plugged into the Real-Time System. Then a reboot will launch the full automated application update process. (the "RT LEDs" will give feedback when the process is finished)
I tried also another way but without success:
Step 1: Add a ZIP File into the Project Explorer : "My Zip File"
Step 2 : Configure the "My Zip File" => Add "My Real-Time Application"
Step 3 : Build "My Zip File"...but the Result was bad :
But anyway, if the would be successful there are a lot of more steps needed:
- sending the ZIP to the customer
- unpack ZIP
- find Real-Time System at customers network
- a FTP tool is needed to update the system.
- There is no way to stop the running Application (from a PC without NI-Software)
Conclusion:
The update with "ZIP" is far away from a comfortable solution.
IDEA #2
If the Real-Time System has a running webserver (the thing which is using Silverlight),
then the application could be updated by using a webbrowser.
So, first we have to update the webserver on the Real-Time System (as difficult as updating the application)
