LabVIEW Real-Time Idea Exchange
Mads
Format and install OS on target from LabVIEW project
Status: In Development
It would be very convenient if we could format and install the OS/RTE on a target directly from the project window.
Currently, if I'm about to deploy a new application I typically format the target, install the OS software on it, then I deploy the application onto it...and finally I make an image of it that will serve as a way for others to deploy the application to production targets.
This involves use of NI MAX (format and install OS), LabVIEW (deply app) and RAD (make image). Doing all these operations (image-making as well would be great) from LabVIEW would make the workflow much nicer.
PS. In the project window today you have Utilities>>System Manager. The described operations should be available directly from the menu, but it would also feel natural to have these options from the system manager.
1 Comment
Deborah_B
Status changed to: In Development
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
