I need a simple way to stop, from a PC, the startup application (if any) running on the RT system. This would work without prior knowledge of what is running on the RT.
This could be VI based solution that I could use in developing a startup upload application.
This would allow me to FTP new application files to the RT system as new startup code. Currently, if there is a startup application running on the RT system I cannot replace the application file since it is in use and I cannot stop the application without having access to the LV development system. I want too make this upload process into a user run software application for a PC connected to the RT system - without the user having access to the LV development software.
