LabVIEW Interface for Arduino Discussions
Sensor Support Request
hi guys just looking for a hand with a)i2c MPU-6050 b)i2c HMC5883L
cheers
Message 31 of 57
(4,571 Views)
Hello Everyone,
I am looking for support for  Triple Axis Accelerometer & Gyro Breakout - MPU-6050, it's a great board with both a 3-axis accelerometer and a 3-axis gyroscope, it has some awesome specs,
found here     https://www.sparkfun.com/products/11028
and here        http://www.i2cdevlib.com/devices/mpu6050#source
very few boards come close to this one
It would be great if it can be supported in LIFA, or a VI which can read its accel/gyro
Thank You
Message 32 of 57
(4,571 Views)
Hi Sambo
I am new to Labview and NI just downloaded the file u put up and tried to run it but keep getting an error message 5003. The error message is coming from the DHTXX Subvi. I have tested my connection with the arduino and it do work
Message 33 of 57
(4,571 Views)
You will need to give more details.  What Arduino are you using?  Also, post your VI.
Message 34 of 57
(4,571 Views)
I am using the uno-R3 connected with a USB and the vi is the same vi which is on this form. when i run the vi Error 5003 occurred at DHT11.lvlib:Read Data.viLabVIEW Interface for Arduino.lvlib:Init.vi. A timeout occurred while trying to read form the Arduino.
Message 35 of 57
(4,571 Views)
Please follow the steps in
LabVIEW Interface for Arduino Setup Procedure
replacing the 6th step firmware with ‘LIFA_Base.pde’ or ‘LIFA_Base.ino’ included in LIFA DHT LV09.zip previously posted.
I also found the following alternative procedure to be helpful as well:
Getting Started With the LabVIEW Interface for Arduino
Good luck
Message 36 of 57
(4,571 Views)
Hi Thanks for the reply
got it communicating now but i am getting some wierd numbers, same problem Morvy187 was getting in the video he posted.
Message 37 of 57
(4,571 Views)
Thank you mate for your help got it working.
Message 38 of 57
(4,571 Views)
Message 39 of 57
(4,571 Views)
Is there a VI for TMP36 temperature sensor in Labview 2012? I saw a 2013 VI for this sensor but not 2012.
Message 40 of 57
(4,571 Views)
