LabVIEW Interface for Arduino Discussions
Sensor Support Request
could u plz show the arduino code of this program..??
Message 51 of 57
(2,870 Views)
What light intensity sensor are you using, and does it integrate well with Labview? I am having trouble finding a sensor that is sensitive and still integrates with labview though I'm not working with fluorescent light, just LEDs in visible light.
Message 52 of 57
(2,870 Views)
aroberts,
I have been working on sensing many different wavelengths of light using several different sensors. For ambient visible light, you might want to try using the TEMT6000 from Sparkfun (https://www.sparkfun.com/products/8688). They are cheap and very easy to setup an analogRead.
As I am doing fluorescense measurement, I needed a very low light sensor so I switched to a PIN photodiode with sensitivity in the wavelength I was trying to detect. Then I amplify that signal and convert it to a voltage using a high precision amplifying circuit. Here is a link that has several circuits that I've gotten good results with. http://www.hamamatsu.com/resources/pdf/ssd/si_pd_circuit_e.pdf.
Best of luck.
Message 53 of 57
(2,870 Views)
someone could help me to obtain the preassure and temperature from   BOSCH BMP180 pressure sensor plz
i'm newbie with I2C comunication type, srry with my english
Message 54 of 57
(2,870 Views)
Thank you very much for help. I try to resolve this problem for long time. thank you. i m new in lifabase use !
But what about connection of pin of DHTxx ? is it analog?
Message 55 of 57
(2,870 Views)
Since you are new, I would highly recommend that you do not use LIFA
because it is old and unsupported. You should use LINX instead.
http://www.labviewmakerhub.com/linx
Message 56 of 57
(2,870 Views)
I want to know the VI  of bmp180 kindly help me with it
Message 57 of 57
(2,870 Views)
