Manzolli
Replace the Invert Circles in Compound Arithmetic Nodes
Status: New
The tiny circles that represents inversion of the operation in the compound arithmetic node are hard to see (http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enlarge-the-Invert-Circles/idi-p/1023748#A3241). The proposal is to get rid of the circles and invert the central part of the respectives connectors:
The difference between the suggestions is that in the second the corners were rounded to reduce the impact a little. I liked the first most.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
18 Comments
PJM_Labview
I don't really like using colors other than the standard light yellow and black in primitives.
What about using the first idea while keeping the dot?
PJM
vipm.io | jki.net
elset191
I'll play too
Tim Elsey
Certified LabVIEW Architect
silmaril
I like this idea!
In case you don't like the idea of introducing additional colors, what about this:
I think this is very logical for the inputs, since it uses the same symbol as the Not-primitive (there is just not enough space for the triangle).
I am not shure, if we should keep the circle on the inverted output, though.
The output inversion basically changes the operation from OR to NOR (or AND to NAND, XOR to NXOR), which is already reflected by the change of the operation symbol.
If this change of the operation symbol is implemented in LV, the basic primitives "Not Or", "Not And" and "Not Exclusive Or" should be changed in the same way, of course.
...and I was just too lazy to paint larger circles, but I think they should get at least one more pixel in each direction.
Dragis
i like silmaril's mockup with the invert symbols in the empty area available on the node itself. the inversion dots can then become an optional element from the right-click menu.
James@Home
Jim,
I agree this is an area that needs improvement.
However, I agree with Darin.K that the change needs to be consistent across all boolean functions that have invertion.  The only method, IMHO, that makes sense is to enlarge the circles and possibly fill them with a different color.
LabVIEW 5.0 seems so long ago...
James@Home
Jim,
I'm way late on this feedback, but I agree this is an area that needs improvement.
TomOrr0W
Looking at the comments on this idea, I ended up searching invert, negate, bubble, and circle (skipping anything that was already marked duplicate).  I figured I might as well link the related ideas.
Strongly Related:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enlarge-the-Invert-Circles/idi-p/1023748
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Compound-Arithmetic-with-inverted-input-should-be-eas...
Related:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Offer-a-Positive-Logic-Alternative/idi-p/1022834
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Negate-option-on-Comparison-functions/idc-p/3793254
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Shortcut-to-Invert-Input-Output-in-Compound-Arithmeti...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Correct-the-quot-not-quot-symbol-by-removing-the-inve...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Automatically-invert-compound-arithmetic-inputs-when-...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/General-Comparison-Operator-as-an-Express-VI/idi-p/12...
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Simplifying-Boolean-expressions/idi-p/1890963
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Invert-Option-in-all-Boolean-Terminals/idi-p/1281058
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Invert-signal-going-into-a-select-VI/idi-p/2224232
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Negate-input-on-boolean-functions/idi-p/1084159
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Array-String-not-empty-function/idi-p/3163821
TomOrr0W
Strongly Related:
Related:
