Vision Idea Exchange
Nezarovsky
Color analysis
Status: Declined
I'm working on a school project which is a resistor sorter. I'm tried to use the color segmentation from the Vision assistant but I couldn't get a match because the clasifier I used was based on a resistor and can't be used if I changed the resistor. I've also tried this VI but I can't determine the color code via the RGB profil .
1/ How can I make a clasifier file to include all possible colors?
2/ How can I modifie my VI to get the RGB values of only the bars?
1 Comment
Brad
Status changed to: Declined
I would not put this in the Idea Exchange, but in the Discussion Forum:
https://forums.ni.com/t5/Machine-Vision/bd-p/200
In the mean time, I would use an edge detector to find the bands, and then just use a small region of interest to classify just that 1 band.
To create a color classifier, go to start and type "Color Classification" to open the wizard for training different colors. Once you have a classifier file, you can use Vision Assistant to create a sample script that uses this file and generate code from there, or you can check out the shipping example "<LabVIEW folder>\examples\Vision\Classification\Color Classification.vi"
Once you have classified all the bands, you can use the following example to get the resistor value
https://forums.ni.com/t5/Example-Programs/Resistor-Calculator-Example-using-LabVIEW/ta-p/3504651
Hope that helps,
Brad
