what is the process to monitoring and control some reservoir and pupm?
Hello
can u help me?
I have some water tank and some pump. I want monitor and control tanks level but Im new in labview.
what tools i need?
what is the process of camputer until hardware?
can u give me step by step process?
Message 1 of 23
(4,352 Views)
Take a look at this thread, it may be helpful: monitoring unknown tank level and control
Message 2 of 23
(4,327 Views)
tnx chembo
that is my topic too.
my new question is different
best regards
Message 3 of 23
(4,324 Views)
Step by step process-
1. Learn LabVIEW using the freely available courses. Read through the LabVIEW help.
2. Come back here and ask for the next step.
Pointless trying to jump into a project when you're not even familiar with LabVIEW. This may not be the answer you want, but it's the most helpful answer in terms of bringing you long-term success.
Message 4 of 23
(4,292 Views)
If you don't know what sensors you have or how to program them if you do, I'd either follow toecutter's advice or pay someone to write a program.  You'll never find the answer otherwise
Message 5 of 23
(4,280 Views)
Hi behzad,
you really should mention your very related older thread
Message 6 of 23
(4,268 Views)
@GerdW wrote:
Hi behzad,
Wasn't it being linked in Message 2 and him acknowledging it sufficient?
Message 7 of 23
(4,251 Views)
Hi
@GerdW wrote:
Hi behzad,
In that topic I try to find a way to use of wizard for input data. however I wrote all process. but in this topic,  I'm trying to find
operational way to implement all of my project.
actually, I need details of process. I know I have around 16 digital input/output, I have around 10 analog input. I want contol pump activity. my sensor are ultrasound level meter,pressure gauge,thermometer and like these.
Best regards
Message 8 of 23
(4,195 Views)
Hi behzad,
you need to learn the basics of control systems. Wikipedia is a good source…
LabVIEW comes with a lot of control algorithms. PID is included in the current version, in older ones you need to install (and buy) the PID&Fuzzy toolkit…
Message 9 of 23
(4,165 Views)
Hi GerdW
tnx.
I'm acquaint with the basics of control systems. I want use of an optimization alogorithm in mathscript node instead of PID in this step.
I want input an excel file and some manual set as Input of system to exe program. and then start work. can u explain dedtails from program, interface, and hardware connections? is necessary any toolkit yet?
Message 10 of 23
(4,150 Views)
