table
Dear,
 Made this small Vi, it receives data from rs232 the he receives from the vi changes when i do something on the machine.
the first data it receives should appear in the table in colomn 0,0 and may not change anymore, the rest of data should appaer
in column 0,1 0,2 .... but the can change, how can i make the fisrt data in colomn fixed tha it change nomore
Message 1 of 50
(5,955 Views)
Hi drek,
a table is a "2D array of strings" in LabVIEW. You don't create such a 2D array of strings in your whole VI…
- Create such an array and keep it in a shift register.
- Replace the elements you like to write to with the strings you receive.
More hints:
- Don't use BytesAtPort with serial communication. It is (nearly) everytime the wrong command…
- Right now you try to set element [0, 1] in your table with either a numeric value or an empty string. Do you really want to delete the element when "Set Value" is FALSE?
We talked about creating tables in your other thread. I thought you already know how to build up arrays/tables…
Message 2 of 50
(5,934 Views)
Dear Gert,
As you see i never give up 🙂 would it be possible to change the vi so i can how i should do it ?
it would learn me to know labview faster
Thx
Message 3 of 50
(5,930 Views)
Hi drek,
like this:
Initialize the array and replace the elements as needed. Then display the array in your table…
Message 4 of 50
(5,916 Views)
Hi Gerd,
Gonna try it asap let you know, but many thanks for helping sometimes i need a helping hand 🙂
Message 5 of 50
(5,912 Views)
Gerd where can i find the symbol right under set value where the zero is connected ?
Thx very much
Message 6 of 50
(5,892 Views)
Hi drek,
in the Array functions palette. It's named ReplaceArraySubset…
(Didn't we talk about replacing array elements before?)
Message 7 of 50
(5,886 Views)
thx found it 🙂
Message 8 of 50
(5,872 Views)
sorry for the stupid questions Gerd tis is the only array subset i find
Message 9 of 50
(5,860 Views)
You need to find Replace Array Subset.  It is in the top-middle of the Array palette.
Message 10 of 50
(5,850 Views)
