select which plot to view on a waveform chart
Hi guys,
              i am logging about 30 channels of data and would like to have 1 waveform chart with a drop-down box which allows the user to select one channel to display on the waveform graph, i cant figure out how to do this, i cant seem to find a relevent property node in the chart options.
Thanks Zac.
Message 1 of 12
(7,558 Views)
Hi friends
I am Joseph from London.
This is good idea I agree with your suggestion.
Joseph
Message 2 of 12
(7,550 Views)
Accepted by Zac_Acal
I’m not sure if you have a chart or a graph, you mention both. Hhere’s a possible solution for a chart (live data arriving in the loop), a graph would be very similar. You could handle the selection change with an event structure rather than the shift register. Hope this gives you some ideas. Ian
Message 3 of 12
(7,538 Views)
If you prefer not to use a seperate dropdownlist, you can work with shortcut menus as well.
The attached example is LV 8.6.
hope this helps,
Norbert
[Edit] Corrected small error in example
Message Edited by Norbert B on 02-19-2009 07:31 AM
Norbert
Expert: Geometry
Message 4 of 12
(7,534 Views)
Hi Norbert. I like your way of using the menu, I’ve not spotted that before. Ian
Message 5 of 12
(7,529 Views)
Thanks guys, thats just what i needed.
Zac.
Message 6 of 12
(7,522 Views)
Hang on a minute....
when i create an "active.plot" property node it doesnt have the "plot.visible" bit on it.  How can i creat a property node with active.plot and plot.visible like in your examples?
thanks Zac
Message 7 of 12
(7,519 Views)
Just enlarge the property node by one (drag the "bottom" down when the mousepointer becomes an up/down-arrow) and select as new (second) property plot >> visible.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 8 of 12
(7,517 Views)
Or right click on the property node and click "add element"
Cory K
Message 9 of 12
(7,513 Views)
thanks i've found it now.
I'm still struggling, i'm trying to create a seperate plot for a number of front pannel numberic indicators, so each indicator will have its own plot.
I dont understand where the multiple plots come from in your examples, you use a random number in a for loop, so is the loop itteration what creates the plots e.g 10 itterations means a graph/chart with 10 different plots ?
and how do i feed my multiple numeric indicators or local variables in to different plots, and how do i specify which is which, e.g numeric indicator 3 is plot 1 or what ever...
Thanks Zac.
Message 10 of 12
(7,512 Views)
