orthonormal scale
yeap, will try that. Was had that someone had come across that issue before, but doesn't seem like it so far.
Kentmey
Message 11 of 29
(2,648 Views)
* was hoping that...
Kentmey
Message 12 of 29
(2,647 Views)
@Kentmey wrote:
@altenbach : but wouldn't this keep the same scale during the plotting? or will this keep updating?
This thread is quite busy, so I am not sure what you mean by the word "this". The graph will keep the same scale and aspect ratio, even if the data is updated.
Another option would be do make your own from scratch using a picture indicator.
Message 13 of 29
(2,642 Views)
"this" refers to your option with 1, 2, 3. Won't the data end up out of scale after a while then?
Kentmey
Message 14 of 29
(2,636 Views)
Well, that depends on the data, of course. 😄 You can always get the max (abs(x) and abs(y)), round to the next highest integer, then set all axes accordingly, keeping things square.
Message 15 of 29
(2,630 Views)
Accepted by Kentmey
Gave it a try, but didn't get it to work at all.
Kentmey
Message 16 of 29
(2,611 Views)
Kentmey,
It is time for you to show us what you are trying.  Please post your latest VI along with some data and an explanation of what is not working.
Lynn
Message 17 of 29
(2,594 Views)
I am not sure why you marked this post as solution, because it certainly does not sound like one! 😄
For a simple example using a picture, open the example finder and look at the example named "Waveform and XY Plots.vi". Here is an image of the front panel. Both "graphs" are simple picture controls.
Message 18 of 29
(2,582 Views)
He must have discovered that it's impossible.  LabVIEW has no provisions for doing such a thing.
Tim Elsey
Certified LabVIEW Architect
Message 19 of 29
(2,568 Views)
Sort of, made a square graph ( with some assistance from NI engineer) with maximum of the axis the max of x and y axis. Kind of makes the trick. Thanks for your help and ideas anyway.
Kentmey
Message 20 of 29
(2,559 Views)
