Targetdir error even though Documents folder exists on Win7 PC
I have seen many reports of the Targetdir error and the probable solution is to check if the documents folder exists in the user/public path.
However in my case, the folder exists and still I get this error.
I use Win7(64 bit) on a Core I7 PC with Labview 2011(32bit).
Only some installers have this problem. Other apps compiled on LV2011 work just fine.
Any workarounds ?
(3,266 Views)
Additional information :
I am trying to install the software NOT in programfiles, but in C:\PackTest folder
But this same concept is used in my other VIs and installers also and they work fine.
Only some dont.
I even tried RUN AS ADMINISTRATOR. but of no use.
(3,263 Views)
I've incurred the same issue with LabVIEW 2010 built install program.
OS: Win7, 64 bit running on Intel i5-2520M CPU.
I'm trying to install in a folder other that c:\Program Files.
I've varified that settings per knowladge base 4W28DAN5 are correct.
(3,222 Views)
Hello Leroy.
I am somehow not sure if your post is a confirmation that you also have the same error or is it a solution linked to the KB you mentioned.
Rgds,
Rohit.
(3,205 Views)
Hello Rohit,
Sorry for the lack of clarity. I do have the same error and the KB didn't fix it.
I've since discovered that LabVIEW 2011 fixes the bug.
Referance: http://www.ni.com/white-paper/13257/en
See ID 277725
Leroy S
(3,193 Views)
