orthonormal scale
Dear All,
Please find attached a copy of some code which has the effect Kentmey desires in LabVIEW v11.  I know that this code is poor - I wouldn't reccomend using insert into array or XY graph inside a while loop but the code is really to demonstrate how to use the XY graph property node using XScale and Y.Scale minimum and maximum values to generate a `manual auto-scale' if you like.
Robert Ward
Applications Engineer, NI
Message 21 of 29
(2,320 Views)
I managed to achieve something even nicer actually.
Size of the graph dynamically changing with the data.
Kentmey
Message 22 of 29
(2,306 Views)
Which ensures that the scale always remains orthonormal AND the graph still autoscales.
Kentmey
Message 23 of 29
(2,302 Views)
I don't think it is a good idea to set the plot size programmatically. What if somebody would enter 1000000, for example.
I would always keep the graph size constant, make the plot area square, and set the x and y scale the same, based of the absolute max of all x and y values.
Sice you are clearing data on each call, it is absolutely not necessary to use the build xy graph express VI and going to dynamic data. That's just way too much! Simply create a complex array as folllows and you are all done:
Message 24 of 29
(2,294 Views)
What about this version?
In this version of my software, this works absolutely fine (this piece of code is integrated into a bigger software, people don't write data in). Does the job nicely and work for me.
Kentmey
Kentmey
Message 25 of 29
(2,287 Views)
Doesn't look much different to your earlier attempt.
You still did not disable "autoadjust scales" from the right-click...advanced menu as I recommended. This means that if e.g. the y scale needs more space, (e.g. because the numbers are bigger), the plot area will randomly change. This needs to be disabled!
Message 26 of 29
(2,284 Views)
Actually not. try with big numbers, you will see
Kentmey
Message 27 of 29
(2,277 Views)
OK. If you disable "autoadjust scales" you would not need to mess with the size at all at run time.
Message 28 of 29
(2,274 Views)
Ok
Kentmey
Message 29 of 29
(2,264 Views)
