Showing results forĀ
Search instead forĀ
Did you mean:Ā
enum to string
Ton posted "I doubt that, ..."
Lets say that I had also mentioned that behaviour was observed under LV 6.1 Real-Time, would you still doubt it?
Please see here. So if I am crazy I have been constantly crazy. Smiley Very Happy
Ben
Message Edited by Ben on 07-10-2008 01:01 PM
Message 21 of 34
(5,046 Views)
Sorry, I must have mist the fineprint Smiley Very Happy
Ton
My LabVIEW Ideas
Message 22 of 34
(5,039 Views)
i am getting corresponding ring value from other source... i just wanted to  match the string to corresponding value from the source... i already made one ring ctrl, that i made as a strict type control.
find this attachment, in that array variable type and data format i made a ring control with defined value, i just wanted to extract these information  and show in table.
in above source mentioned as array.
Balaji DP
Message 23 of 34
(5,019 Views)
Hi balaji_dp...,
one solution is to create a property node of the control inside the cluster with "Strings and Values". Search for your selected value and show the corresponding string.
Mike
Message 24 of 34
(5,013 Views)
Perhaps I'm just a little dense this morning, but it seems that the user is now asking for something completely different (wouldn't be the first time around here), as in matching a string to a list of values. I see no string input in your VI, Mike.
Message 25 of 34
(4,985 Views)
ya you got my point .....!
this is the thing i finding for.....
i need to show the value of corresponding string only......
Balaji DP
Message 26 of 34
(4,974 Views)
can you explain that one again?
more slowly and clearly?  šŸ˜‰
Message 27 of 34
(4,972 Views)
i have the third party instruments, for that i made a driver to access through labview.....
when i am read the variable type of i/o's  that will be return only a numbers.. like 50, 52, 54, 56... these values are corresponding that strings of I/O's type like digital input, digital output, analog input, analog output......
also, i can send (write) the variable type to that third party instruments....for that i made a ring control for my flexibility.... in my ring control has for strings and values are like  digital input - 50, digital output-52, analog input - 54, analog output - 56....
i cant able to change these values (Values in ring control), because the hardware will keep indentify only these values only....
i done coding for writing variable type to the controller .....
at the moment i want to retrieve the string corresponding values from the ring control.....
find this attachemtn
Balaji DP
Message 28 of 34
(4,964 Views)
Hi balaji_dp...,
sorry for my last post, but i think it“s not complete wrong. You can change it to string and then you should get what you need.
Hope it helps.
Mike
Message 29 of 34
(4,944 Views)
Thanks, this is more useful for constants šŸ˜‰
Ben escribió:
Mike and Jorge,
Try "format into string".
I think you'll like it. Smiley Wink
Ben
Message Edited by Ben on 07-10-2008 08:37 AM
Message 30 of 34
(4,364 Views)
