Web Server Not Enabling
Good luck with that...
There must be a config file somewhere that gets written during the web-based server configuration. Does anybody know where that is? I've spent a great deal of time looking for it with no luck.
Message 11 of 44
(5,367 Views)
I tried calling Friday and no one seemed to know the answer to any of that. Apparently someone gets assigned to unsolved forum posts so hopefully our problem isn't falling on deaf ears. It is nice to know that someone else is having the same problem as me, unfortunately. I still need to install 10 on my home PC. Didn't get the install done until late last night and I wasn't going to wait around for LV to install.
Message 12 of 44
(5,359 Views)
First try building the application. After you build the application, Execute the execution file. It will automatically create the initialization file (same as the name of your application name) in the same directory of your executable or where you told it to place it. Try adding the following line to your initialization file:
WebServer.Enabled=True
Rerun the program, This should populate the rest of the ini file.
Message 13 of 44
(5,350 Views)
The weather monitor project doesn't have an executable that is built, just the web service.
Message 14 of 44
(5,347 Views)
Then you are going to have to build the file by hand and locate where it is going to read the ini file.
Message 15 of 44
(5,341 Views)
I just found this ongoing topic:
http://forums.ni.com/t5/LabVIEW/Error-while-configuring-Application-Web-Server-in-LabVIEW-2010/td-p/...
It's directly relevant, though currently unsolved.
Message 16 of 44
(5,321 Views)
It may or may not be relevant, the last post on an unresolve error deals with an application that has an executable.
Message 17 of 44
(5,314 Views)
Hi everyone,
I'm looking into what could be causing this problem with the web server.  What kinds of settings do you have under LabVIEW -> Tools -> Options -> Web Server?
Message 18 of 44
(5,299 Views)
Heads up, after a reformat and a fresh install of 2010 (not SP1). Weather update works correctly. This did not work under my previous setup.
Here are my settings:
Enable Remote Panel Server: Checked
HTTP Port: 8000
Remote front panels: Checked
Snapshot: Checked
SSL: Unchecked
Use Log File: Checked
C:\Program Files\National Instruments\LabVIEW 2010\resource\webserver\logs\access.log
Visible VIs: "*" Checked and Allow access, Use Default Checked
Browser Access List: "*" and Allow viewing and controlling selected
Application Web Server: http://localhost:3580/#/WebServerConfigExtension;component/WebServerConfigExtensionPage.dyn.xaml
Port: 8080
Enabled: Checked (this would never check before)
64 Bit Selected
I will try installing SP1 right now
Message 19 of 44
(5,295 Views)
Installing SP1 broke it.
Worked without SP1, installed it and now it doesn't even let me go to the localhost:3580's web service configuration page.
Edit: I had to go into admin tools -> services and manually enable NI Application Web Server... something I couldn't do before I reformatted and now the weather update works.
Message 20 of 44
(5,287 Views)
