Convert/Import TDMS to Excel
The article I linked to in my previous post literally has a file called Example Batch Conversion which generates several TDMS files, then converts them all.  Here is that link again.
https://forums.ni.com/t5/Example-Code/TDMS-to-XLSX-Conversion/ta-p/3511652
Message 31 of 57
(4,311 Views)
Hi Settler, you can try this also:
Select Multiple Files With Native LabVIEW Dialog Box
Brian G.
Message 32 of 57
(4,305 Views)
Hi Hooovahh
Thanks for you kind help
The Vi is perfectly fine for a single file.
Could you please help with selecting all the files at the same time, the Example Batch Conversion didn't work for me it seems some subvi are missing!.
Is there any way to convert the tdms file to mat files??
Best Regards
Rajab
Message 33 of 57
(4,222 Views)
Message 34 of 57
(4,190 Views)
Oh and what subVIs are missing?  They wouldn't happen to be OpenG VIs would they?  Because I mentioned under the requirements that OpenG is needed.  And I even went through the process of generating a VIPC with all the OpenG packages needed and named it OpenG Packages Needed.vipc and included it.
Message 35 of 57
(4,169 Views)
Hey can anyone help
I've been trying to download Open G toolkit, but I just keep getting this message:
"this package is not compatible with your operating system or any Labview version installed on your computer"
I've Vi PACKAGE MANAGER INSTALLED AND lABVIEW VERSION 2011, 2012 AND 2013.
Rajab
Message 36 of 57
(4,129 Views)
What version of OpenG are you trying to install?
Message 37 of 57
(4,126 Views)
Message 38 of 57
(4,121 Views)
version 4.0.1.9 I've tried with 4.0.0.6 as well
Message 39 of 57
(4,117 Views)
VI version 2014
Message 40 of 57
(4,113 Views)
