The TDM MATLAB Example shows how to read TDM and TDMS files from within the MATLAB® from THE MathWorks software environment.
Supported Features:
FILE EXTENSION: *.TDM; *.TDMS
DIRECTION: Read / ----
LAST CHANGE: September 2020
Description-Separate-2
If you copy the TDM dll and the header file into "C:\test\", you must specify the location in your m-script like this:
examplePath = 'C:\test';
hfile = [examplePath '\nilibddc_m.h'];
loadlibrary([examplePath '\nilibddc'], hfile);
Keep in mind that this provides only the capability to read TDM/TDMS files with the MATLAB® software environment and that the example has been tested with MATLAB® Versions R2007a, R2007b, and R2008a. It is expected that the example will work with earlier versions as well.
Important: Please follow the licensing and installation instructions in the files license.rtf and Readme.txt which are part of this download.
MATLAB® is a registered trademark of The MathWorks, Inc.
How-Separate-2
Related-Separate-2
Hello.
I have a question. How can I get the sampling frequency or the sampling period from my .tdms file?
I am looking for a utility to import TDMS files into Matlab that works out of the box. This code may be useful to developers, but definitely isn't useful for my purposes. For starters, it deletes all of the useful data after it plots it. Secondly, it doesn't import all of the data I need, like the sampling frequency and channel start time. I tried using the nilibddc.chm included in the package to look up the properties to add to the code, but it's just a list of help topics with no help pages attached. I don't know how else to describe it, there's an index of help pages and they're all blank. When I was setting up my experiments, I used TDMS because the page explaining TDMS includes the phrase: "NI has developed an example demonstrating how to read TDM and TDMS files from within the MATLAB® from The MathWorks software environment." which links to this article. If I had known it was going to be this much of a pain, I would have used another logging method. For all of the money we are paying for Labview and Matlab, I really expect better. Don't advertise that you have a utility to import data into Matlab if it doesn't work out of the box.
I am looking for the TDM DLL. Ultimately I try to load a tdm file into Matlab. Unfortunately I can't find this DLL on you site and the link for this example in Matlab seems broken.
