When using the "Open FPGA VI Reference" function you can configure it to reference the FPGA build/bitfile in three different ways:
- Build specification
- VI
- Bitfile
In development mode I often use "Build spec", for deployment I switch to "Bitfile". When using this function it behaves different, depending in which mode it is configured! This makes for a bad "User eXperience"…
In "Build spec" mode:
- when double clicking the pink border of the function it opens the referenced FPGA VI
- you need to right-click the "Open FPGA VI reference" and select "Configure…" to open the configuration dialog
- when selecting the "Build Spec" radio button it opens a selection dialog (probably a listbox) but you can't double click the build spec you want to use, you need to select the build spec and then click on "OK" button
In "Bitfile" mode:
- when double clicking the pink border of the function it opens the configuration dialog, (you don't need to right-click the "Open FPGA VI reference" and select "Configure…" to open the configuration dialog)
- when selecting the "Bitfile" radio button it opens a file dialog and but you can double click the bitfile you want to use
(All this relates to LabVIEW2014SP1. Haven't tested this with LabVIEW2015 so far.)
I propose the idea to make this behaviour consistent, independent of the selected mode in the configuration dialog!
I wish this behaviour:
- double click on pink border of the functions opens the configuration dialog
- double click on the FPGA VI icon shown inside the "Open FPGA VI reference" function opens the FPGA VI
- double click on an item in the "Build spec" selection dialog selects the build spec
