Currently, when you add a new (not existing) cRIO controller and chassis to a LabVIEW project, there is no check as to whether this is a valid configuration or not. For example, you can successfully add a cRIO 9072 controller with a 9112 chassis to a project, even though the 9072 is a controller with an integrated chassis. I believe that the LabVIEW Project interface should notify the user (via dialog box) that this is not a valid configuration before they can add modules and start developing code to use an invalid configuration.
