LabVIEW Real-Time Idea Exchange
speineer
RealTime, scan engine synchronization EtherCAT clock
Status: In Development
For the use of a variator that generates his own clock and distributes it on EtherCAT, I need to make the RT loop synchronous with clock posted on EtherCAT by the variator.
So would require the scan engine parameter is in receipt of the EtherCAT clock.
This function is imperative on Labview-RT to be compatible with ability to manage EtherCAT variators ( Beckhoff).
6 Comments
Deborah_B
Hi speineer,
You can already add 3rd party hardware as EtherCAT slaves, where cRIO is the master. To clarify, you're looking to synchronize LabVIEW RT loops (or the entire scan engine) to a clock generated by a 3rd Party EtherCAT device, where that device is the master?
Deborah
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
SunainaK
NI Employee (retired)
Hi speineer,
You are correct that Real-Time code is not synchronized to the EtherCAT Distributed Clock, so we cannot synchronize the Real-Time code with the Variator clock.
We are aware of this gap and your feedback is appreciated. Do you have an example of a variator from Beckhoff which could benefit from this functionality?
Best,
Sunaina
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
Deborah_B
Status changed to: In Development
Deborah Burke
speineer
additional informationundefined
speineer
update
undefined
SunainaK
Hi speineer,
Thanks for the schematic! I will be sure to pass it on to R&D.
-Sunaina
Sunaina K.
