If you try to select "Run As Startup" before having built the application you are stopped by LabVIEW with the phrase "The Real-Time application has not been built. You must build the application before deploying."
This is bad behaviour. Instead LabVIEW should silently do the requested task, including any prerequisite ones (the build), or at least offer me to grant it access to do so. The Run As Startup choice already includes the deployment option (no complaints from it if I have not done that yet), there is no reason why it could not do the build as well.
