I can currently write code that uses the SysConfig Restart VI to run some cleanup operations and then shutdown a cRIO.
However, if I rebuild my startup application in LabVIEW, and then want to deploy it (or want to restart from MAX) then I have no easy way to call this code when restarting - the cRIO restarts and any handles are left open/half-open until the other end clears them up.
Could we have the ability to register a shutdown VI that is called whenever the target is programmatically restarted (e.g. by LabVIEW's Project Explorer or MAX)?
I understand that in the case of failure and a hard reset via the Reset button then probably this is impossible/implausible, but in the "normal" workflow, this would be a useful addition.
