I find the process of initializing Maps in LabVIEW to be unintuitive and inconsistent with the initialization process for other similar concepts (such as, say, arrays). After some initial trial and error, the process I've settled into for creating maps is to drop a map constant, and then to drag and drop the appropriate data types onto it for my key and value. I first looked for an Initialize Map VI (which doesn't exist) and then tried to create the constant by wiring up appropriate types to an "Insert Into Map" and creating the constant from there -- but this doesn't work as expected because the terminals don't update appropriately.
What drove me to coming to the forum today though, was that in creating a malleable VI with a map inside of it, I found a breaking point for the "drop constant and drag values into it" approach. Since the map data types need to be dynamic to support malleable VIs, I've had to get creative to get around that...
