A right click option for each auto indexed array that allows will not use the length of that array in choosing the number of iterations. If there is no input to the count terminal all auto-indexed terminals can go beyond their length otherwise at least one must remain as a driver for determining the length. If multiple are left with the default (existing) behavior, the shortest length will be used. For any iteration where the array is shorter that the "i" of the loop, the defaults for the data type will be returned (just as if "index array" blocks had been used inside the loop.
Similarly the loop could be set to use the longest array instead of the shortest.
Additionally a similar function could be done when any array compare or math functions are done. In the case of compare functions if set to use longest array, the result will be false for any compare to an empty element of the shorter array, and math functions will use the default data type for empty elements.
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/New-modes-on-auto-indexed-input-array-tunnels-in-loop...
