This idea was posted years ago and declined for lack of interest (it got 6 out of 7 necessary, but I would have been the 7th!). I would like to bring it back, I would like my application to have access to it's own version number. In fact you can open the project programatically and see some build properties but not that one. I can then grab the version from the build properties and set the default values on my FPGA code before compiling.
I was trying to make a pre-build VI that would look at the build properties and copy the version data into a control. Can't be done. I find this very useful to make sure that my RT system and my FPGA code have the correct versions.
Same as with an about box, or version checking for compatibility.
The previous thread suggested a routine in the FileVersion.llb but that seems to only be available in a single platform. Not useful for RT linux or Mac. The version is not available until the executable is built which does not work for FPGA.
At the moment my only recourse is to hand copy the version from the build properties and then set those as a series of 4 integers on the FP. (Then select them all and set their values to default, hence the other suggestion about right click)
