User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
LabVIEW 2020 allows you to remove the event property nodes shown here:
It's a nice feature because these nodes are often not used and can get in the way. However -- the process for removing them is a bit tedious: you have to either remove them all individually or size the cluster down to one and then remove through a menu. I find that I rarely use this because, well, it just takes too long.
However...if you could just click on the node (it's already selectable) and then click the "delete" button on your keyboard, this process would be near-instantaneous, and I know I'd be much more likely to use it.
