User | Kudos |
4 | |
2 | |
2 | |
1 | |
1 |
In MultiColumn listboxes there is a very useful (but slightly hidden, I'm sure a lot of people do not know about it) option that allows you to set the properties of entire rows or columns in one go by setting the active row or column to -2. Similarily you can set the properties of the headers by setting the row to -1.
However, if you want to set the properties of all rows or columns *except* the header, there is no such shortcut available; you have to first use the -2 option, then use -1 to undo the action on the header...
Idea: Add a third shortcut (-3 ?) to select all except the header.
