06-10-2022 01:18 PM
@Christina_R wrote:
@PhillipBrooks wrote:
I looked at the SSH functions and see a 'Execute SSH Command' function. This appears to be non-interactive.
Will there be an interactive 'session' based feature as well?
Thank you for your feedback! We're considering adding a session-based API for SSH, but it won't be in the LabVIEW 2022 Q3 release.
Is there a way to use the "Execute SSH Command" function interactively? What is the use case proposition without the 'session" feature if most usages require a session to persist?
06-16-2022 10:05 AM
We had many customer requests for the ability to run a command remotely, without a session. We are aware, however, that this doesn't cover all use cases.
06-23-2022 04:19 AM
The Beta is just LabVIEW, right? No RT or FPGA toolkits?
06-23-2022 08:59 AM
Yes, that's correct.
06-29-2022 03:25 PM
How many requests did you have to run SSH without a session? Are you sure that they wanted SSH without a session, or did they assume you'd understand that a session was required? It seems that a session is required for most use cases.
06-30-2022 07:17 AM
Why not add SSH as an NI-VISA resource type?
TCPIP0::192.168.1.100::22::SSH
Then all NI products that support NI-VISA could use SSH!
07-12-2022 05:24 AM
Interesting idea, but I'm not sure about the feasibility for a number of reason:
- NI-VISA hasn't seen any major (or even minor) additions in quite a long time. This is partly because NI-VISA isn't really an NI product anymore but managed by a consortium that has to agree on pretty much everything before it can be done. But it's also because I think the NI-VISA developers pretty much all have moved on to other positions and there isn't much of a full time support crew for its development anymore.
- SSH might require some additional functionality similar to what USB raw required. If it is just property additions it could be done without changing LabVIEW itself by simply adding those properties to the visarc file, but otherwise it would require modification of the VISA specification AND the LabVIEW VISA interface.
07-12-2022 10:34 AM
@Rich_Y. wrote:
Has anyone out there successfully activated the beta?
I have installed the Linux Version in Ubuntu 22.04 LTS run in Oracle VirtualBox 6.1 - as mentioned on the download page, I had to be logged into my NI account to download the .iso
In contrast to LabView 2021 community, the LabView 2022 Q3 beta is installed successfully from the mounted .iso via the INSTALL script
for some packages, there shows up a warning or rather notice - which are said to be ignored safely
07-13-2022 05:59 PM - edited 07-13-2022 06:08 PM
Did the activation problem ever get solved?
(I recently installed on a VM but activation always fails using the given number. I have until the 18th to fix it, then it will stop working...)
07-13-2022 07:01 PM
Hi @altenbach. By chance, are you using IPv6? If so, do you get desired activation results if you disable IPv6?
When originally reported N months ago, the request internally got routed to IT, but a work item never got back to me. I'll follow up internally to learn more, and copy back here if there's anything noteworthy to share.
