07-26-2008
01:08 AM
- last edited on
01-27-2025
09:22 AM
by
Content Cleaner
07-28-2008
04:12 PM
- last edited on
03-01-2026
05:05 PM
by
Content Cleaner
Hi Presario2100,
In Measurement and Automation, after clicking on the FieldPoint system in the Remote Systems section of the configuration, on the Network Settings tab, you should see Time Server as an Additional Configuration. The time server has to be an NI Logos time server. NI Logos Services install with NI FieldPoint, LabVIEW Datalogging and Supervisory Control (DSC) Module, and Lookout. The first suggestion I have is to install (or re-install) the latest version of the FieldPoint drivers from here. Please let me know if this helps.
07-28-2008 11:17 PM
07-29-2008 10:43 AM
07-30-2008 03:59 AM
07-30-2008 09:37 AM - edited 07-30-2008 09:38 AM
08-01-2008 01:41 AM
08-01-2008
06:15 PM
- last edited on
01-27-2025
09:23 AM
by
Content Cleaner
Hi Presario2100,
There are documents that may help you along. Please see:
What Ports Do I Need to Open on My Firewall for National Instruments Software Products?
Using Lookout, LabVIEW DSC and Network-Published Shared Variables with Firewalls
As for your timestamp question, let me look into this a bit more. What you described is expected behavior, but there may be a work-around.
08-15-2008 05:57 PM - edited 08-15-2008 05:58 PM
Hi Presario2100,
In order to obtain an updated timestamp with each FieldPoint Read, you should use a Flat Sequence structure. In the same frame as the FieldPoint Read, use a Get Date/Time In Seconds node.
The program obtains a fresh Timestamp each time the FieldPoint Read VI is called.
