05-10-2021 08:34 AM
@Yamaeda wrote:
wiebe@CARYA wrote:
The array to cluster + unbundle has the advantage of being 'vertically friendly'.
I'd say a Get Matrix Size saves you a couple of blocks.:)
For some reason I never remember to use it.
(It was mentioned earlier. This thread is way to long.)
06-02-2021 03:25 PM
This thread is mostly about Rube Goldberg LabVIEW code. Occasionally a verbal code description can be considered Rube Goldberg, sometimes it borders on gibberish. I suspect that the following reply was written in some foreign language and then butchered by some translation software. Can anyone guess to original language? Can anyone get any useful information out of all this?
@JethTran wrote:
Hi....In the event that you Write a variety of ones and zeroes to the Array of Boolean Indicators, the qualities will mirror the 1 and 0 of the source exhibit.
The source can be the aftereffect of some interaction, a steady positioned on the Block Diagram, or a Control put on the Front Panel UI. The Write work is refined by the utilization of a wire joined from the source symbol to the sinking symbol of the marker exhibit.
On the Block Diagram you will see a Constant, Control or other interaction Source wired to the symbol of an Indicator that is a variety of like measurement and type to the source.
Maybe you should shows us and illustration of your own work so we can appropriately resolve the particular issue you are having as opposed to driving us to be general and vague in noting your solicitation.
06-03-2021 09:05 AM
Grammar is too good to be a translation, sounds more like the poster was intentionally vague and cryptic with his/her response 😄
06-03-2021 09:12 AM
Strangely, he also created his account just to answer that
06-03-2021 06:09 PM
There's also this:
Switching "an" for "and" isn't a mistake translator software would likely make.
06-03-2021 06:59 PM
Another possibility is that someone tries to do some posts to get the account verified so that they can later use it for spamming. NI currently does not allow new accounts to post more than one or two posts a day.
I also regularly see posts that sound gibberish and illogical but the person doing them clearly choose some gibberish that actually almost makes sense in respect to the thread topic. But then there is the unavoidable spam link at the end of the post.
06-04-2021 01:14 AM
Just yesterday i reported a reply that was basically "Visit this indian review website" with a link.
Newly created account and that was their only post.
06-09-2021 03:58 PM
Slicing and dicing some waveforms:
(And since all probably have the same timing information, it might be worth sticking to simpler datatypes)
06-18-2021 02:28 AM
06-20-2021 12:08 PM
So somebody posts some convoluted code, I post a reply with a simple demo 1/4 the size of a postcard, but the OP considers it "really complicated" and creates the following much simpler (NOT!) implementation instead, spanning three screens and basically violating every single rule for event structures and sane coding practices.
How does one respond to that? 😄 Sigh!
