BreakPoint
Rube Goldberg Code
@Jacobson-ni wrote:
wiebe@CARYAwiebe@CARAYA wrote:
Not bad, not bad at all. It saves a click to see what's in the other case, to make sure or to find out it's empty!
Just hope you don't lose errors down stream by not handling the case of a for loop executing 0 times.
Same can happen in a case. Use default instead of wiring through, and the error is lost. In a For Loop, a shift register. Exactly the same: if you write bad code, you get bad results.
Message 1991 of 2,639
(12,901 Views)
wiebe@CARYA wrote:
@BertMcMahan wrote:
While this isn't exactly OVERLY complicated, it's something I shamefully admit to doing when I first started teaching myself LV. I didn't know about Case structures, and needed something to execute or not based on a boolean, so here's my janky boolean solution:
I have not investigated it recently but NI did have a Patent on a 3-D diagram that provided your perspective of the diagram was right, you would be able get a glimpse of more than one case at a single glance.
Ben
Message 1992 of 2,639
(12,883 Views)
True greater than a boolean?  I had to run some test code to find out that it gives the same result as a NOT.
Seen here.
28.6.18_BD
Message 1993 of 2,639
(12,764 Views)
And the NOT can of course be implemented as invert on the compound AND.
Message 1994 of 2,639
(12,741 Views)
So we have a case structure (boolean selector) where the contents of the two cases are identical, differing only by a boolean diagram constant that we already have. (See here)
I don't think that case structure is needed at all!
Message 1995 of 2,639
(12,605 Views)
Rube Goldberg code often looks complicated, so for something a little easier to look at, here's deceptively simple Rube Goldberg code.
(The poster claims 1 year "LabVIEW experience", whatever that means. Maybe in another few years he might stumble across the stop button by accident :o. We just need to be patient! :D)
(Seen here)
Message 1996 of 2,639
(12,520 Views)
(Seen here)
Really Christian,   haven't you ever seen the Abort Button?  😄
Damnit it's hard to type in a phone when you're screen is covered in coffee because you forgot to swallow before reading a post
"Should be" isn't "Is" -Jay
Message 1997 of 2,639
(12,506 Views)
(Seen here)
There's even a button on my computer case that seems to work just fine if I press it long enough. 😄
Message 1998 of 2,639
(12,501 Views)
Seen on a l
LabVIEW thread I recently replied to.
Kudos for a link and picture
I know, let's build all of these scalar values into an array then IMITIATLY wire it directly into an index array to get the scalar values back.  Look no wire branches.
Message 1999 of 2,639
(12,369 Views)
(Seen here)
What's the matter?
Is that "X" in the upper right hand corner of the window not a good enough stop button for you? 😛
=== Engineer Ambiguously ===
Message 2000 of 2,639
(12,292 Views)
