BreakPoint
LabTOONS, The secret life of LabVIEW objects!
@Ben wrote:
Queue-BYTE?
See "cubit" 🙂
Message 221 of 230
(8,672 Views)
@AristosQueue (NI) wrote:
See "cubit" 🙂
I thought you were trying to make a qubit reference but this makes much more sense. Well, as much sense as measuring things with cubits can possibly be.
Message 222 of 230
(8,653 Views)
See "cubit" 🙂
I am familiar with a "cubit" and use it regularly particularly when working in the woods. "Is a log long enough to bridge a stream?" for example.
Spoiler
My point was related to the "bit" part since there is no "bit" data type in LabVIEW. Even Booleans are (?) are actually 16  bit (correct me if I am wrong). There are bit-wise operations but they operate on U8s or larger.
So no "bit" only "bits".
Splitting hairs I admit.
As an old guy that has actually seen and trouble-shot a bad bit I just had to make the distinction.
The original joke was rather clever and I liked it.
Ben
Message 223 of 230
(8,623 Views)
Message 224 of 230
(8,618 Views)
Saw this on Reddit and wanted to share.
Message 225 of 230
(2,841 Views)
why would you feed the blue I32 array constant into the build array primitive?
Message 226 of 230
(2,761 Views)
Because then the result is IP IP Array? Without it it will just be IP IP.
Spoiler
Message 227 of 230
(2,759 Views)
So the output would be "IP IP Array", and sound like "Hip Hip Hurray".
Message 228 of 230
(2,749 Views)
@Ben wrote:
Queue-BYTE?
See "cubit" 🙂
Of course, if we assimilate "to be or not to be" with "cubit" we get "Qubit"
Message 229 of 230
(2,697 Views)
I read that as "Hip Hop Horray" and thought "Hoovahh must be a Naughty by Nature fan."
Message 230 of 230
(2,685 Views)
