BreakPoint
LabTOONS, The secret life of LabVIEW objects!
@danil33 wrote:
Very Intresting and funny......... altenbach.You made your studies and researches very funny and Intresting.Iam verymuch glad to see this thread you have posted, after 4 long years.Also LabTOONS will be helpful to freshers for proper understanding ABOUT LabVIEW.Anyway KUDOS!
Check out G-Wiz! (just google it or follow Bens signature)
"Should be" isn't "Is" -Jay
Message 201 of 230
(16,456 Views)
Not in my signature yet so see here for G-wiz.
Ben
Message 202 of 230
(16,434 Views)
Definelty found a gem in the breakpoint forums. It is sad that altenbach didn't have time to continue it. Hope he will come back to it or grant permission to the community members to continue it.Smiley Very Happy
Message 203 of 230
(16,275 Views)
Some puns are irresistable once conceived.
Message 204 of 230
(15,840 Views)
Message 205 of 230
(15,823 Views)
Taking one of Altenbach's and updating it...
Message 206 of 230
(15,027 Views)
OK, here's a new one in a new format, touching on classic drama.
Message 207 of 230
(15,014 Views)
I wish I could give more than one Kudoes!
Ben
Message 208 of 230
(14,971 Views)
Strangely.  I once developed a test set for a widget that communicated some data via a serial packet where each packet consisted of
Header (STX)
Length (1 byte calculated on total packet length Or, Data Size *2+3)
Data (ASCII String)
NOT Data (NOT(ASCII String))
Checksum (U8) as the lowest 8 bits of the sum of all Data and Not Data characters cast to U32. (to avoid overflow with the addition per the code comments)
You may see that device every day.
Message 209 of 230
(14,963 Views)
In my feeling it would need a boolean answer/solution
something like
Greetings from Germany
Henrik
LV since v3.1
Message 210 of 230
(14,479 Views)
