This is about a debugging function in VBAI I miss. If I have a state diagram of some complexity, I might want to start some states combined with each other.
What I currently already can do:
- Run the whole Inspection Once / in Loop / until Failure
- Run a single State Once / in Loop
What I would wish to do:
Think of the following diagram: I have two cameras, triggered and run with independent branches of the state machine, as in this picture:
I want to run only one of the branches, i.e. for debugging. Now I would like to do something like this:
Current workaround:
I can run „Set Camera Trigger 1“ once, then „Get and Process Image 1“ once, that would have the same effect (as „Run States Once“)
Not sure if this would work for all your cases, but it might be easy enough to temporarily modify your transitions so they force the flow to always go through the paths you want to test/benchmark. I like your idea though, but in mean time, this might help.
