USRP Software Radio
Does LabVIEW support HackRF?
Hello, Sir. Your ideas are great. But how did you do that? Could you give us more details?
Best wishes!
Message 41 of 49
(3,761 Views)
hello sir, I donnot know the process to make the CMmakefile.txt. But I try my best to solve these issues, I don't know what happen. Gould you give me some help? Thank you very much.
Message 42 of 49
(3,754 Views)
能不能提供编译好的LabView需要的.Dll与.h文件。最好是有案例!谢谢
Message 43 of 49
(3,717 Views)
Hello, there was a problem with in-phase pairing of two (three) Hackrf. When you try to allow one device to apply to clkout 10 MHz, an error appears. Someone already solved the sub-complexity? help me please
Message 44 of 49
(3,186 Views)
Hi, I am using your program in LabVIEWx64_examples. But when It runs , I get error 1172.
I use LabView2020 sp1 64,and i try the method of nethack.dll,it can't worked.
I'd be grateful if you could help me. thanks
Message 45 of 49
(3,105 Views)
"Thank you. You can get IQ data from "Stream" object. I've made another example VI with detailed comments. I hope it would help you.
Also notice that this example is using x32 version of NetHackRF assembly. If you want to open it in LabVIEW x64 than you should copy rx_example.vi to folder with x64 assembly (which I've sent earlier) before opening it."
Hi, can you compile it to an older LabView version 16  (X32)?
Thank you
Message 46 of 49
(3,024 Views)
Message 47 of 49
(2,983 Views)
Hi makar853,
Thank you for your assistance!
Message 48 of 49
(2,972 Views)
Hi makar853 and Eldueno
I am trying to use rx_spectrum_example 64. When I run it, after a second or so, I get an error message. Do you have any suggestions about what to do?
Error pic attached.
Thanks!
Message 49 of 49
(1,911 Views)
