USRP Software Radio
Does LabVIEW support HackRF?
makar85, very good job!the question also arose: Can you advise how to get I\Q parameters from your model?? at least in which direction to go?
Message 11 of 49
(6,384 Views)
Thank you. You can get IQ data from "Stream" object. I've made another example VI with detailed comments. I hope it would help you.
Also notice that this example is using x32 version of NetHackRF assembly. If you want to open it in LabVIEW x64 than you should copy rx_example.vi to folder with x64 assembly (which I've sent earlier) before opening it.
Message 12 of 49
(6,366 Views)
P.S.: don't forget to unblock nethackrf.dll before opening LabVIEW.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019UnoSAE&l=ru-RU
sometimes windows can block it.
Message 13 of 49
(6,357 Views)
Thank you!
I'm trying to implement a spectrum analyzer on hackrf with your help, but hackrf is very convenient for this, and the 20 MHz spectrum view width allows you to conduct interesting experiments for educational purposes.
Message 14 of 49
(6,325 Views)
Does anyone have a python example?
Message 15 of 49
(6,064 Views)
 makar853,   Hi!
Were you able to implement a spectrum analyzer on HackRF in LabVIEW ??
Message 16 of 49
(6,006 Views)
Sure, just make complex FFT of IQ data, get modulus of FFT result and optionally convert it to dB, something like that.
Message 17 of 49
(6,001 Views)
 Thanks! the spectrum is displayed perfectly! 🙂
Message 18 of 49
(5,964 Views)
Has anybody had success with the hackRF_sweep function in labview?
Message 19 of 49
(5,955 Views)
I've added sweep_init and sweep_start to nethackrf.cs but I haven't properly debugged it yet. If you want, I can send you a compiled dll. Which version do you need? 32x or x64?
Message 20 of 49
(5,936 Views)
