USRP Software Radio
Does LabVIEW support HackRF?
I get the same error message (USBAPI is 1.02 need 1.04).  I guess I will try building hackrf firmware from scratch and flashing to see if that fixes.  My Cmake skills are bad though
Message 31 of 49
(5,944 Views)
I think, this should help. I've just found usb_api_version defined as 1.04 in usb_descriptor.c in master branch.
Message 32 of 49
(5,937 Views)
Ha I just saw that and was going to post this
Message 33 of 49
(5,933 Views)
well i tried to compile from hackrf firmware from source from master with new USB-API on windows for the last few hrs but hit a road block and am giving up for now.
Message 34 of 49
(5,924 Views)
Hi, i am using your program in LabView 2020 (64-bit). It runs well, can receive signal. but, whenever i stop the program. I get error System.NullReferenceException. I'd be grateful if you could help me. thanks
Message 35 of 49
(5,835 Views)
Hi, I've never seen such errors. Does your program close stream and all references before quitting? References to created objects should be closed in reverse order. Also have you tried examples from this thread? Do they throw same errors?
Message 36 of 49
(5,829 Views)
i use rx_example.vi and add spectrum.vi to plot the spectrum that HacKRF received. it has closed stream and reference. But, still throw the same error. I attached the program. thank you.
Message 37 of 49
(5,822 Views)
Here try this and see if you still are getting the errors.
Message 38 of 49
(5,798 Views)
Thank you, i really appriciate it. I still have the same issue. It seems i have problem with USB port on my hackrf. i will try your program with another hackrf. btw, what's the difference sample frequency and count?
Message 39 of 49
(5,786 Views)
Sample frequency means how many times per second driver would copy readings from ADC to driver memory. "Count" argument of read function means how many readings you want read from driver memory. Sample frequency must be in range from 2 MHz to 20 MHz for hackrf. While "count" can be any number you want. If I get your question right.
Message 40 of 49
(5,779 Views)
