USRP Software Radio
Does LabVIEW support HackRF?
Thanks for the reply, how about both.
Message 21 of 49
(5,535 Views)
Ok. I also included example for labview x32. But there's a new problem: hackrf.dll which I've sent earlier is too old. So sweep functions wouldn't work with it.
Message 22 of 49
(5,532 Views)
Just so I'm clear, the x64 has the sweep and the x32 does not, correct?
Message 23 of 49
(5,529 Views)
Both nethackrf.dll has sweep functions, but to use them you need new libhackrf libraries (hackrf.dll). Both hackrf.dll which I've compiled and sent earlier are too old. You need to compile or find current version of hackrf.dll. Source code to compile hackrf.dll is here https://github.com/mossmann/hackrf/tree/master/host/libhackrf/src but it's easier said than done.
Message 24 of 49
(5,526 Views)
This is where I get into trouble, I'm a strictly LabVIEW user, so what would I use to compile the dll? I do have the latest PothosSDR libraries, which has a HackRF.dll in it, would that work?
Message 25 of 49
(5,524 Views)
Maybe it would work. Try to replace old hackrf.dll and restart labview process. If not, you would get error 1172 because of missed "hackrf_start_rx_sweep" function.
Message 26 of 49
(5,515 Views)
I get this error...System.BadImageFormatException
Would it be possible for you to recompile your code with the correct hackrf.dll so the sweep function works?
Message 27 of 49
(5,512 Views)
This error means that you are trying to open x32 library on x64 labview or vice versa. I think I would compile it on this weekend if i'm not busy.
Message 28 of 49
(5,506 Views)
That would be great, I really appreciate the help.
Message 29 of 49
(5,503 Views)
I've compiled new libraries. But I still can't debug sweep functions. Now I'm getting HACKRF_ERROR_USB_API_VERSION error. I've tried to update hackrf firmware, but USB API version is still 1.02 while sweep functions require 1.04.
Message 30 of 49
(5,467 Views)
