Mauricio-
You are correct. This is the error I am receiving. However, I am a bit confused as to why the magnitude is ever greater than 1. When the modulation parameters are generated, this always seems to be the case automatically. Furthermore, the generate parameters VI accomplishes this without any knowledge of what the RF power is. I have verified this, for example in the QAM transmitter example, by probing the QAM parameters and verifying that the symbol magnitudes are <1.
However, I did discover something interesting. I am not currently using any baseband filtering. However, if I choose the Root Raised Cosine filter, things work fine.
This partially makes sense in that filtering the original IQ pairs changes their value....however....I've verified that the symbols that are originally generated have a magnitude <1...so if I don't use any baseband filter, the should be the same. Why do they turn out >1?
Brandon
